주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nexus S는 Google과 공동-개발한 스마트폰이며 Samsung은 Android 2.3 "Gingerbread" 운영 체제를 사용하는 최초의 스마트폰이었습니다.
Left vertical Area unresponsive
I bought a uses nexus S and found that it had an unresponsive to touch area of the screen. This area is a 1cm large rectangle.
Which parts should i replace to get back a fully working screen?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
선택된 해법
Montasser Ben Gadri, usually when the digitizer (touch) is unresponsible at a certain area of your screen, it is the digitizer that needs to be replaced.
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
Thank you very much for your answer. Is it easily replacable? Where do i find the cheapest place for nexus s digitizers?
Thank you for accepting my answer. Sorry, nothing is ever really easy, but it is not a bad job. Check on the teardown Nexus S Teardown it does give you a good idea what's involved. You can also check om here http://www.repairsuniverse.com/samsung-g... As for the cheapest place, it really depends on your geographical location.I tried Google and average price ~$120....Hope this helps.The reason for that is cause the Digitizer and the LCD are a lot easier to change as one unit....
http://www.ebay.co.uk/itm/New-OEM-LCD-Sc... $80... but it's from china, so you'll have a wait on delivery.
Thank you for your great help.
댓글 달기
답변을 추가하세요
Montasser Ben Gadri 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 753
