주요 콘텐츠로 건너뛰기
TaoTronics TT-SK10 does not charge properly
When I plug in the power cable, the power indicator is turning on for a sec and going off right after a sec
Tried resetting the speaker but no luck.
Any suggestion on how to fix this charging issue?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
How to open the speaker? In my case after trying so many times the port is out from the board. Now, unable to use the speaker. Can anyone help?
Very useful info by estqwerty. I contacted Tao Electronics for information regarding change of batteries and their answer was that the batteries are irreplaceable. Thanks for sharing the detailed pics and the methodology.
댓글 달기
답변 2개
가장 유용한 답변
One of the cells in the battery is gone. open and change it.
There are no skews under the rubber feet.
You need to open it, first pop up the decorative sides. unscrew the bolts from the wide speaker side, not from the side that are 2 speakers. There are 4 clips up and down on the metal cover. There are 8 more skews and you will have access. The battery is 2000mah 7.4v on single connector. replace cells or single cell in my case and it works again.
It is surprisingly reparable.
이 답변이 도움이 되었나요?
점수 2
댓글 4개:
Thank you for the instructions and the pictures, it is very useful. However, I do not manage to remove the metal cover. Whatever the tool or the force, it bends the metal. I do not see or feel clips. Could you give more details about this step? That would be great!
@oliv40807 look at shte pick with metal cover removed - remove the screws. straighten the metal pins slightly were the screws holes are , to be able to get it out from the place or slots. after that prime and pop the wide side there are small hooks or bumps. look at the pic.
I got access to the battery, as shown in the last photo, above. I've unscrewed the plastic plate on top of the battery. That said, the battery seems wedged in there pretty well. How do I get it out of there? I can't seem to pull it out from the ends with the tips of my fingers. Any suggestions?
Hi, I'm having a very hard time removing the decorative side covers on my unit. It's almost like they're glued in place but I just can't get any leverage without nicking and marring the plastic on the unit. How did you manage to remove yours?
I need to gain access to the USB port so I can resolder it back in place as mine has broken off.
댓글 달기
Hi,
Have you tried a different compatible, known working charger or charger cable and checked if it started to charge, you didn't say?
Use a magnifying glass and a bright light and visually inspect the charge port enclosure for any obstructions such as lint etc . Also check that the pins are all there and that they are not broken or missing.
If this is any obstruction in the enclosure do not use a metal pin or probe to get it out, as you may damage the pins. Try using a vacuum cleaner instead.
If the port looks OK then try the following:
Plug the charge cable into the port but do not connect the other end of the cable to anything!
Then grab the speaker firmly in one hand and grabbing hold of the inserted cable plug with the other hand try to gently, stress gently move the cable plug up and down and side to side and check if any movement of the charge port is detected.
If there is it may be loose from the circuit board or even if not the speaker will have to be opened and further testing done to find out what’s wrong.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
palmo Industries 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 8
지난 30일: 40
전체 시간: 940
