주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
슬림하고 가벼우며 세련된 Swift 3는 이동 중에 작업하기에 이상적인 노트북입니다. 최신 NVIDIA® GPU와 Intel® CPU를 탑재하였으며 긴 배터리 사용 시간을 제공합니다. 우아한 실버 섀시에 13.5형 3:2 비율의 2256x1504 IPS VertiView 디스플레이를 선택하거나, 14형 16:9 FHD IPS 디스플레이의 선명한 색상을 선택할 수 있습니다.
My laptop won't charge
Hey, so my laptop has stopped charging after 3 years. I tried a different power cable but that's all. The problem could be anywhere form the power pack down. I've never had any issues like this before so I have no idea what it could be. Should I try to fix it myself?
Don't really want to spend 200 euro to repair something that cost me 800
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개:
At least try to open it up and see if you find anything obvious (burnt components, water damage, etc...) Maybe post some photos of the motherboard...
Hi,
What is the model number of the laptop?
댓글 달기
답변 3개
Check the AC adapter brick and verify that any removable cords are fully inserted. Make sure the battery is properly seated in its compartment, and that there is nothing wrong with either the battery or laptop contact points.
There are also some basic troubleshooting steps you can follow.
Otherwise remove the battery completely from the laptop and try running the laptop using the AC adapter. If you can use the computer for a couple of hours without problems, the adapter is obviously okay. Clean the battery contacts. Replace the battery and try charging it again.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Check the connector and the jack.
If the pins are no longer sticking out enough to “grip” when inserted - (maybe) all you need to do is bend them a bit so they provide the holding power they used to - when everything was new.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
It's probably the charger l bought a charger off ebay for my laptop and I thought the laptop was broke but it wasnt broke something was wrong with my charger.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
danielforbes1 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 13
전체 시간: 6,219
