주요 콘텐츠로 건너뛰기
9월 20일 출시한 Apple의 2019년 주력 스마트폰으로 6.1" LCD 터치스크린, 이중 카메라, 그리고 여섯 가지 색상으로 제공합니다. iPhone XR의 후속 제품입니다.
475 질문 전체 보기
iPhone 11 has TrueTone option but has "non genuine Apple display"
Hi there :)
I’ve replaced display and copied/ flashed (using iCopy Plus) data from original one so I got TrueTone working but…… iPhone still reports it is no Apple Display.
I know it is non Apple Display - but - I was hoping to see this as TrueTone data copied.
Is that “genuine Apple data” about display is somewhere else?
How can it be copied?
Thank You
Bart
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hi this could be a long shot but when I am buying screens I know there’s a table at the bottom to compare different screen qualities. The lowest grade screens have the True Tone field unchecked so even if you bought it and copied the data true tone still wouldn’t work. Like I said this could be a long shot but I believe that’s what happened.
Example (scroll down to see what i mean): https://www.iparts-4u.co.uk/iphone-x-dis...
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I know what you mean about that - as I had this problem before with other iPhone 11 - I could toggle TrueTone on/off - BUT - display did not changed its "colour temperature"
But this fake replacement changes that "colour temperature" - oleophobic coating feels like genuine - FaceID works great etc.
So that is the reason it is weird for me - it has working TrueTone toogle and changing "colour temperature" but - it has that message it is non Apple - where I thought that "data" will be copied too (because "True Tone" been copied)
Ah I see, so the True Tone works but the message stays, correct? Probably apple messing with their software again to put people off unauthorised replacements. Just like the recent ipX update where replacing rear camera will disable faceID as reported by jessa from IpadRehab
댓글 달기
귀하의 답변을 추가하세요
Bart 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 16
전체 시간: 426
