주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
Microphone problem after screen replacement
Hello.
When I replace the display with a new LCD, then I screw the tape with (speaker-microphone-face id etc), while recording the front camera I hear a slight squeaking in the background. But when the tape is on the outside of the screen, it is all ok. Is it maybe some kind of lack of grounding in the screen? Is there any method to change it? (in the original display everything is fine) Any suggestions or help are welcome.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Yes, I checked everything. This little golden clip does not eliminate the problem. Flex is ok, everything works fine on the original screen.
댓글 달기
답변 3개
Did you place back the little gold grounding clip as can be seen in step 22 of this guide? 아이폰 X 스크린의 교체하기
Also double check the flex cables to ensure they are not damaged.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
댓글 달기
I have 350 of the same replacement displays, I checked 30+ lcd's and they all have the same problem. (little noise - “piiiiii” when i recording front camera)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
This is an issue with bad quality replacement frames. Sometimes it is easier to use a good quality screen to save the hassle.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
So you are saying that in my replacement displays, weak aluminum or other metal was used during production, which interferes incorrectly with the phone casing?
댓글 달기
답변을 추가하세요
Lucas Szeyk 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 6
전체 시간: 641
