주요 콘텐츠로 건너뛰기
Samsung에서 제조한 Samsung Galaxy Note 5는 (Note5로 불림) 스타일러스를 탑재한 phablet/패블릿 스타일 휴대폰입니다, 2015년 8월 출시.
271 질문 전체 보기
How can I test my new replacement screen on Note5 no charge on battery
I am in the middle of a screen replacement repair on my Samsung Note 5. The old screen is already out, I need to be able to test the new screen before install but how can I test the screen if my battery is dead and it's not advised to plug in phone while testing? My battery is good I just need to be able to give it a charge before hooking up the new screen to be able to test.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
you will have to just connect the screen but do not fully attach it to the phone, and plug in the charger, if the display does not light up with any charging icons you’ll have your answer. if it does light up then you can simply finish the replacement from there.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I guess if that is my only option, what I meant by testing was running the IOTEST screen from special input codes. Testing all functionality. I see what your saying though. I thought about hooking my old screen back up just to put a little bit of a charge. I can tell power going in from blue light indicator at the top left of phone. Thanks for the input I will let you know how everything goes.
댓글 달기
귀하의 답변을 추가하세요
Susan Harrell 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 58
