주요 콘텐츠로 건너뛰기
Nexus S는 Google과 공동-개발한 스마트폰이며 Samsung은 Android 2.3 "Gingerbread" 운영 체제를 사용하는 최초의 스마트폰이었습니다.
28 질문 전체 보기
Nexus S fell on concrete. Display broken.
My new Nexus S just fell on a concrete. Afterwards there is nothing shown on the display. I receive calls and I can see image when I expose it to direct sunlight (or strong room-light) otherwise the display is black. Which part of it might be broken and what should I buy to replace it? Help really appreciated.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
I would most certainly start with the LCD. It is available here and I am sure at many other places as well. The instructions are here and it looks pretty straight forward. Good Luck.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
it seems that the backlight in the LCd has gone bad. The backlight is part of the LCD and therefore you would need to replace the LCD itself. There also might be damage to the logic board itself but you would need to physically inspect it for damage and replace parts as needed.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
What is Logic Board? Would it be expensive if I need to repair it too?
Ceck your model.
i9023 has LCD screen, but i9020 is AMOLED and does not need a backlight.
댓글 달기
귀하의 답변을 추가하세요
Pero 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 2,047
