주요 콘텐츠로 건너뛰기
2011년 상반기 모델, A1278 / 2.3 GHz i5 또는 2.7 GHz i7 프로세서.
782 질문 전체 보기
Can I exchange parts between a MacBook Pro 2011 early and a late one?
hello, I would like to know if I can exchange some parts between a macbook pro early 2011 and a macbook pro late 2011, the hard drive, the battery, the display and the ram, thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Yes! The two 2011 runs are using the same hardware.
The best way to think this is looking at the series ID string. So looking at yours MacBookPro8,1 we can see all of the different CPU options Apple used which is the only difference in the 13” models.
In the 15” 2011 models MacBookPro8,2 there is also a discreet GPU which is either a AMD Radeon HD 6750M or 6770M, otherwise its the same hardware.
FYI: In one of the rare cases Apple used the same hardware in the 2012 models! The 13” MacBookPro9,2 and the 15” MacBookPro9,1
The logic board now offers USB3 over USB2 between the 2011 and 2012, and if you transplant a 2012 logic board into a 2011 system you need a slight modification to the displays LVDS cable to make it fit the socket.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks! it helps me a lot :)
댓글 달기
귀하의 답변을 추가하세요
andy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 26
