주요 콘텐츠로 건너뛰기
듀얼 마이크와 802.11ac Wi-Fi 연결 기능을 갖춘 Apple MacBook Air 중 더 작은 노트북.
149 질문 전체 보기
My MacBook Air won't turn on once I shut it off (water damage)
Dear Community,
I would like to ask if anyone has encountered a same or similar problem, and what the solution could be.
I accidentally pored water on my MacBook Air. After drying it for days in a “tent” position, I tried to turn it on, but no response. When I plugged it in, the charger’s light did not even appear at all.
I opened up the back of the lap top and took it apart to see what is going on. When I reassembled and plugged the computer in, the charger’s light appeared (red), and I was able to turn the lap top back on.
While it is running, everything seems to function perfectly on it.
The problem is that once I shut it down, I am unable to turn it back on. I can only do it if I open the back of the lap to and disconnect it’s battery cable from the board, wait a few seconds, and plug it back on (I do not even have to take out the whole battery, just disconnect it from the board).
I run diagnostics when I turned the computer on, and it suggested me to get a new battery. So I did! Now I replaced the battery, but the same problem occurs even with the new battery.
If I would like to summarize:
-If I shut down the computer, I can only turn it back on when I open up the back, and unplug the battery cable from the board and plug it back on after a few seconds (it is enough to just unplug it, I do not have to take out the whole battery)
-Then I plug the computer in with the charger, and it turns on
-When the computer is on, it is functioning perfectly without any problems or glitches
-If I shut the laptop down, then I can not turn it back on without going through the battery process mentioned above
I am not good at computers so please excuse me if my description is unclear. I would really appreciate any help or advice about what the problem could be and how to fix it, what to replace perhaps.
Thank you so much!
PS. These are the screenshots after running the “coconutBattery 3” app
Update (03/06/2021)
*Screenshots with MagSafe charger plugged in
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 4개
Good! So at this point I see the charger is trying to charge your battery!
Now you need to wait! Leave your system plugged in for a good 10 hours turned fully off and take another snapshot then.
I appreciate your help, but I think I probably did not describe the problem well. So the computer has a good and new battery, I just replaced it recently (after the water damage). It is charging well and functioning absolutely fine.
The computer works without any problem while it is on.
The only problem is that once I shut it down, the only way to turn it back on again is that if I open the back of the lap top and unplug the battery cable from the logic board, wait a few seconds, and plug it back. Then the lap top turns on and works fine!
So I am able to turn it on, but I have to go through this process.
OK, we took a left turn ;-{ Where we needed to take a right!
The power control logic is a MOSFET on the logic board which likely had corrosion damage so its not de-latching.
Think of it like a light switch where the swing arm is not lifting off the contact point. So you can't turn off the light.
This will require deeper skills to locate the damaged area and replace if needed parts.
I understand, and thank you so much for taking the time. I really appreciate it!
It seems like that at the end I need to take it to the store to have it fixed.
At least it is very good to know what the problem could be.
댓글 달기
답변 2개
가장 유용한 답변
Well not good ;-{
The logic board has gotten damaged, on the other side is the logic which deals with the charging (SMC). You’ll need to take the logic board fully out to inspect it for corrosion damage MacBook Air 11" Mid 2013 Logic Board Replacement you may need your logic board repaired or need a new one.
해당 답변은 도움이 되었습니까?
점수 2
댓글 5개:
Thank you so much for your answer.
Do you think it is still the case even that everything work absolutely fine when the computer is running? It is just the only way to turn it on is that I unplug the battery cable from the board from a few sec, then plug it back.
Just want to make sure because everything is really functioning well besides the "turning on process".
Thank you very much for your advice.
@pothos - Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 기존 질문에 이미지 추가하기
I just ran the app you suggested, thank you.
I attached the screenshots at the end of my original post.
@pothos - Let's give it one more try this time with the MagSafe charger plugged in.
@danj I appreciate your help. Just added screenshots with the charger plugged in.
댓글 달기
There’s a possibility that your power button is non functional shorted by liquid that’s why disconnecting and reconnecting the battery is the only way to start the computer. I would check this before replacing the logic board since the problem will not be resolved.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Thank you so much for the advice!
How would you check it? Just simply look for corrosion around the power bottom?
The power button circuitry cross the keyboard goes to the keyboard socket via the keyboard flat cable (pin 5 I think). The short could be anywhere in the keyboard or in the button itself. In this case you need to replace the keyboard but it's not an easy job (metal rivets holding the KB to the case). Better to buy a used top case.
댓글 달기
귀하의 답변을 추가하세요
Kimura 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 10
전체 시간: 169
