주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2012년에 출시된 Apple의 7.9인치 1세대 iPad mini이며, 16, 32 또는 64 GB 저장 용량과 A5 프로세서를 탑재했습니다.
Ipad Mini Won't Respond.
The Mini Ipad does not respond at all. It worked perfectly until the home button was unresponsive. Then, the home screen became like a “glitch” when I turned it back on after I turned it off to do work outside. I can’t press the pass code or anything to get in. Every time I turned on the home screen, it then “glitches” and fades to black. Somehow, the home button was working again but only for the power reset. I then hold both the power buttons to reset it but it then made it worse. I turned it back on, the Apple Logo appears, and then it fades away like a “glitch” to a black screen. I even tried doing it with a charger on as well.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
What happens when you do a soft reset (hold home button & power simultaneously)? If that doesn’t reset it, can you connect to a Mac & restore it?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Blue Dude [G] 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 16
전체 시간: 215
