주요 콘텐츠로 건너뛰기
2nd Generation high performance tablet computer released by Apple on June 2017. Model A1670.
41 질문 전체 보기
Is soldering required to replace *just* the digitizer?
I have a 2nd gen iPad Pro 12.9” and about a month after I bought it, it got dropped and cracked the digitizer. I finally found a decently-priced replacement and was looking at repair videos. To my alarm, it looks like the repair involves microsoldering. Is this the case? Is it literally easier (but ridiculously more expensive) to buy the full LCD assembly with the daughtercard and replace that instead?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Not only it requires soldering but plenty of other tools as well since the digitizer is glued to the display. Display - glue - digitizer - glue - glass. Older iPads had it separate making the replacement a lot easier. The part you need to desolder has chips on it which I believe are married to the motherboard. No matter what screen or digitizer you get you’ll need to desolder it and solder it onto the new assembly.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Mike Morkes 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 11
전체 시간: 159
