주요 콘텐츠로 건너뛰기
The PSP 3000 was released in the U.S. on the 15th of October 2008.
Why is my psp not reading UMD discs?
My PSP is not reading my UMD discs. Please help.
Update (03/26/2021)
It doesn't spin at all. Yes it boots ups. No errors. The discs looks clean. Nothing jammed. Under worked before. It is updated.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
when you put the disc in does it spin up?
if not you may have a tough time.
does it atleast boot up?
does the PSP give any errors?
inspect the disc and see if its dirty.
check to make sure nothing is jammed in the slot of the PSP itself.
is this a UMD that worked before and just doesnt now? or is it a new game?
when was the last time the firmware was updated?
Update (03/26/2021)
so if thats the case there are 2 versions. you need to figure out which one you have. the psp 300x or xc.
both tear down guides are on this site along with the drive needed to be replaced.
X= PSP 300x UMD Drive Replacement
XC = PSP 300xc UMD Drive Replacement
good luck my friend!
PSP 300x UMD Drive 이미지
안내서
난이도:
쉬움
15 minutes
PSP 300xc UMD Drive 이미지
안내서
난이도:
조정
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Joamir Terrero 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 26
전체 시간: 2,334
