주요 콘텐츠로 건너뛰기
The 5th generation BMW 3 Series is based on the E9X platform. The car pictured is a E90 chassis. The E9X chassis was used from 2004-2013 when the F1X chassis was released. When talking about a non-specific chassis, this generation is typically referred to as the E9X chassis since there are multiple chassis for this generation of 3 series, depending on the body style (E90/E91/E92/E93).
How much does it cost to replace timing chain on my 323i 2011
The car showed engine sign second time in the last couple of days. I went to my mechanic and he said the problem is in exhaust VANOS and the filters needs to be changed he said he will clean it if he could to save me some money he cleaned it and switched the filters, he put the exhaust one in the intake and the intake one in the exhaust. And then the check engine sign came back on and I went to him again he said the code is from the exhaust VANOS again the problem might be in the timing chain
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
there usually located on the rear of the engine on bmw, I know in the UK if its accessible without the engine being taken out it is about £700 on average for most cars and around £1,000 or anything that has to have the engine removed (so usually another 3rd of the cost more anywhere), the chain tensioners are renowned for failing in a lot of bmw’s though, have you check that first? and depending on the mileage if the engine does have to come out then maybe a clutch will be required too.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ricky 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 6
지난 7일: 7
지난 30일: 9
전체 시간: 414
