주요 콘텐츠로 건너뛰기
The Lenovo G570 is a 15-inch laptop announced in January 2011.
23 질문 전체 보기
Lenovo internal speakers stopped working? what to do?
This is a very weird situation for me. I cannot get the audio from the internal speakers but If I Use the external speakers. I can get the sound without any errors. What to do in this case? Please help me.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi @robinmartin ,
Try inserting the headphones into the laptop and then gently, stress very gently, wriggle the plug up and down and side to side whilst removing and inserting the plug a few times. and check if this resolves the problem.
There is an internal contact in the headphone socket which is operated by the insertion of the headphone cable plug. When operated it signals the BIOS to disconnect the audio from the laptop speakers and direct it to the headphones. Sometimes this contact can get temporarily stuck in the operated position or worst case it gets bent out of shape and stays operated.
If doing the above doesn’t work you may have to replace the audio port board.
Here’s the hardware maintenance manual for the laptop.
Go to p.53 to view the necessary pre-requisite steps and then the procedure to remove the systemboard. This will give you access to the audio ports board
The supplier linked was only to show you what it looked like and the approximate cost. There are other suppliers online that may suit you better. Just search for Lenovo G570 audio ports board to get results.
Note: When searching for the board I noticed that there seems to be 2 board options. One has a part number of LS-6756P and the other is LS-6751P. If you need to replace the board then you may want to verify which one is in your laptop before ordering. The part number is printed on the board itself. If you zoom in on the part that I linked you can see the part number.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
robin martin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 18
전체 시간: 122
