주요 콘텐츠로 건너뛰기
A mid-range smartphone from Samsung released in 2019.
118 질문 전체 보기
Speakers are not working at all.
Suddenly there is no sound coming out of my phone. I checked for "do not disturb" mode, any Bluetooth connected devices (and turned it off), and even went a step further and disabled my assistant app. I checked *#0*# for the speaker, and it didn't work. Through Samsung Members app I did an interactive check and then it showed that my "in-call speaker" is working but not my "media speaker". I tried to connect my headphones through the AUX jack and it didn't work as well.
From various support forums, I found out that similar problem is present with other users of A50 which leads me to think that the issue is a software problem, especially that it happened suddenly!
Any suggestions about how to resolve the issue, or at least, make sure that it is a software issue not a hardware one? (without resetting my phone).
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 15
댓글 4개
I had the same problem. I found out the phone is thinking that a headphone is plugged. I cleaned the headphone socket and after about times of plugging/unplugging it started work.
Go into the last app it happened in. Turn the volume on and off. For me, it was the game royal match. Turned the volume off and on and my sound magically came back. Weird glitch. I did everything from restarting it, to cleaning my ports, to cleaning my caches, to going into every setting. Nothing worked. Last resort would of been a factory reset but decided to go into evey app and mess with the sounds thinking an app was glitching, which could be messing with the sound... and apparently it was my game app and it worked. Hope this helps someone
I suddenly could not hear YouTube video and did all u did 2 ck it out but 2 no avail. Sometimes it seems when cell phone companies come out with a new phone or that "special deal" our cell phone suddenly need replacing.
댓글 달기
답변 5개
선택된 답변
I appreciate your answer brandon k.
The issue was resolved in a funny way, I turned on vibration mode, then restarted the phone again (just like I did for 20 times earlier), when I switched from vibration back to sound on it worked.
Software bullshit like this is what urges people to make conspiracy theories about the manufacturer.
해당 답변은 도움이 되었습니까?
점수 9
댓글 8개:
the more dependent we become upon technology, the more technology will try to find a way to screw with us. But still... at least now we know another fix to try when this happens!
I had the exact same problem and your inexplicable solution worked perfectly ?. Now that's a hack!
It really worked..thanks a lot
I have already tried this method on my Samsung A50 yet I couldn't hear nothing on my phone speaker even the AUX jack and the mouth piece are not working anymore
Mohammed tuhin
댓글 3개 더보기
댓글 달기
Try force rebooting your phone. Hold the power and.volume button for 7-10 seconds. Phone will vibrate and then reset. This may fix it.
You can also try this if that fails: Activate the developer option in your Samsung Galaxy A50 first by going to Settings > Phone, and tap the seven-time build number. When allowed, go to the Developer option and scroll down to get the Media option. A’ Prevent USB audio routing’ option will be noted there. Switch on the switch by toggling this option.
See of that works.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Hello, happened mine just this morning. It did play my alarms though, I did the interactive checks but nothing comes out of the bottoms speaker, checked my media apps like YouTube, YouTube Music, etc. They don't fire anything, but notifications coming in I can hear the alert. So I discovered something, if I'm in the app, no sound, but if I went to recent apps it will play, but when I return to the app, then no more sound again.
Brandon. Thank you!!! I tried your 1st suggestion. It was scary at 1st because a warning popped up and I couldn't get the phone to just shut down but kept holding the volume. and power button down and eventually the phone shut down. When I turn the phone on the was sound. Thank you! Thank you l! Thank youl!.
댓글 달기
So I did this, hard reset ( hold volume down and power key) also in Vibration Mode. The phone shuts down, still holding the power button, when samsung logo turns up, hold volume down, it will enter safe mode. Then turn off safe mode which will restart the phone again. I hope this helps because I just tried
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Hi
I tried the hard reset option and it worked for a couple of hours then started going mute please help
댓글 달기
Install custom rom (Pixel Experience 12.0) and Mint Kernel. Root the phone. If it stops making sound, follow these steps:
Put on vibrate mode. Restart. Turn off vibrate mode.
It worked this way for me.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
  • Press and hold the power button of your smartphone along with volume down for 10 to 20 seconds.
  • Now when you see the vivo logo start appearing on your smartphone screen release both the buttons.
  • Now your smartphone will start performing force reboot and when this will end you will see your problem will be successfully solved.
  • Clean your ear pice speaker and main speaker
https://howtofixphone.com/samsung-a50-ea...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Amr 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 40
7일 전: 264
30일 전: 1,025
전체 시간: 35,011
