주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
1049 질문 전체 보기
iPhone SE: battery charging only 13% and restarting
Hello,
I dropped my iphone SE (first generation) from a considerable height. It was in a silicone case that popped out after the hit. As a result my screen was damaged beyond repair. I ordered a new one and replace it, but then I noticed that the battery only charges to 3-4%, so it was constantly charging. I thought the reason was the battery, so I bought a new one. After the replacement the problem remained, the battery is charged only to 13% and the phone restarts shortly after opening apps. Powered off the phone and cleaned the plug with rubbing alcohol, nothing changed.
My question is: could this be due to the charging port or is it probably some other hardware problem? If not the charging port, what could be the reason?
I love my phone very much because it is small and I am attached to it. I want to know if there is any chance to save it or it is not worth it :(.
Thank you in advance :)
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Best course of action is to replace the charge port and the battery, due to the charge port most likely being the cause. The battery is just to be sure. The links are included at the end of my answer, as well as the guides. Happy Fixing! TAG2YT | iPhone SE (1st Gen) Battery iPhone SE (1st Gen) Lightning Connector and Headphone Jack | And here are the guides: iPhone SE 배터리 교체 iPhone SE Lightning Connector Replacement
iPhone SE (1st Gen) Lightning Connector and Headphone Jack 이미지
상품
$19.99
iPhone SE (1st Gen) Battery 이미지
상품
$29.99
iPhone SE 배터리 이미지
안내서
iPhone SE 배터리 교체
난이도:
운영
40 minutes - 1 hour
iPhone SE Lightning Connector 이미지
안내서
난이도:
운영
50 minutes - 3 hours
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
Than you for the fast reply!
I have changed the battery already, but the problem reminded.
For this reason I was wondering if it is due to the charge port or something more complicated that will be very expencive to fix.
Like one of the charging components on the logic board for example.
Replacing the charging port would be the best thing, being as it is likely the suspect.
댓글 달기
귀하의 답변을 추가하세요
Zeld Ina 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 46
