주요 콘텐츠로 건너뛰기
The Samsung B1445A is a front-loading high efficiency washing machine by Samsung.
Samsung front load power shut down and door locked
My Samsung front load washer power shut down and the door is locked. I tried the outlet and no response. I can’t even get the model number since the door is locked . I don’t know if this will help but the Samsung washer is a super speed power foam stem VRTplus . I never had issues with it and it suddenly stop while the machine was running.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
What is a Signal button? I am assuming a Signal button is either the Power or Start that I tried separately with the Soil, but no response.
댓글 달기
답변 2개
가장 유용한 답변
Hi,
Have you tried looking on the back of the machine for the model number?
Also try pressing the Soil Level + Signal buttons (both together) for 3 seconds and check if this allows you to open the door.
Update (04/27/2021)
Hi,
Without a model number it is difficult.
This is the user manual for a Samsung VRT that says to press to Soil + Signal buttons for 3 seconds.
But since your model hasn’t got one then try operating the Spin and Soil buttons for 6 seconds as described in this user manual which is also for a Samsung VRT but obviously a different model although its Control panel also shows a signal button as well.
Did you check on the back of the machine for a model number, you didn’t say?
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Wow! I did it. Without finding the model number. How? I started the machine again. Midway, I stopped the cycle. Then I held the start/pause button for at least 10 seconds because this made the water begin to drain. Then I released my pressure on it. It didn’t open. Then I pressed the start/pause button again for 3 seconds and click, it unlocked and opened! Either I’m a genius or I got lucky but there you go! I’m excited to provide an answer here.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Bella 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 34
전체 시간: 3,901
