주요 콘텐츠로 건너뛰기
조이콘 컨트롤러와 약간 더 작은 스크린이 통합된 보다 합리적인 가격의 순수 핸드헬드 버전의 Nintendo Switch의 게임 콘솔입니다. 2019년 9월 20일 출시.
175 질문 전체 보기
L, ZL, -, power, and volume not working after joystick replacement?
Okay, I used the awesome tutorial and replaced the left joystick on the switch, it works great but now I can’t get the above listed things to work. I’ve taken it all apart and put it back twice and once the power button worked but not the volume. Any ideas?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
My best guess is that you have maybe missed the yellow ribbon cable that runs between the daughterboard and the main board.
Otherwise, there is damage to the connectors or cable itself. The fact that the whole of that side in not functioning is good (relatively speaking…).
May I ask how you know the volume, and ZL and L buttons are working if power doesn’t?
Good luck in any case
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Did you fix the problem yet?
I have the same issue after replacing the joystick, new ribbon cable didn´t change anything!
Minus button
ZL
Cross to the right
Power
And Volume Buttons
Dont work at all
I can turn the Switch on by plugging it into the charging cable
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
by "cross to the right", do you mean the plus button?
I mean the DPAD sorry my fault. Up, Down and Left work but not right.
댓글 달기
In my case I hadn't clicked down the daughter board connector cable to the main board. (Bottom of switch.. over battery connector) once I had taken off the cover and shield simply reseating that cable worked.
If more than one thing on the daughter board is not working then it'd highly like that the cable is not seated correctly or is broken
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Tessa Lyon 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 28
전체 시간: 468
