주요 콘텐츠로 건너뛰기
동일한 모델 번호(A1932)와 EMC 번호(3184)를 사용하는 2018년 후반 MacBook Air의 소규모 개선에 대한 수리 정보 및 안내서입니다. 이 모델은 트루 톤 디스플레이와 약간 수정된 배터리가 특징입니다.
100 질문 전체 보기
MacBook Air 2019 Start without Audio-daughterboard
Hi,
My Macbook is not charging or powering up.
The connector on the Audio-daughterboard has a problem
Now my question can i charge and start the Macbook without the Audio-daughterboard connected ?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개:
How about giving us a bit more here, why do you think the audio board is your issue?
This board has a second function as a junction between your TouchID sensor and the main logic board. So without it your system won't work.
HI,
it had a waterdamage and the connector on the Audio-Daughterboard ist broken.
I know that the Touch id is on it .
The question is if it powers up or charges without the board connected
댓글 달기
답변 1개
Without the board TouchID has no means to talk to the main logic board. So you can’t gain access to the system.
Time to replace the part MacBook Air 13" (Late 2018-Mid 2019) Audio Daughterboard and you may need the cables are well.
MacBook Air 13" (Late 2018-Mid 2019) Audio Daughterboard 이미지
상품
$119.99
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
So you mean it will even not charge?
The battery has 0V
@Laniedalos - Sounds like you have more than the audio board that needs attention. The audio board is your headphone jack and Apple loves to do more than one thing when they need a part. Here its a junction point for your power button and the TouchID.
Think of it this way I have two intercom units which is connected by a wire. If the wire is disconnected there is no pathway for the single to get to the other unit.
But having a problem with your battery charging up is telling me you have something much more going on here.
I think it's time to visit someone who can fix your system.
댓글 달기
귀하의 답변을 추가하세요
Laniedalos 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 12
전체 시간: 170
