Nest Cam Outdoor has died - no power light at all
Anyone tried repairing one of these?
좋은 질문 입니까?
좋은 질문 입니까?
I have the same problem and since it was out of warranty, I figured why not try to take it apart. I think it's because there is water in the camera.
I was able to take it apart, and also may have figured out where it leaked from. We had a ton of rain over a matter of a week, and this is when the cameras either failed or had condensation on the lenses. I have 2 cameras out of a dozen or so that failed and they were the ONLY ones that were mounted upside down (where the image was rotated). The only place any water could settle and seep into the camera is through the speaker holes, which are facing up. So I figured that is where the water was coming in.
So moving forward, if the camera is mounted upside down, I would recommend to seal the speaker holes with silicon or duct tape. (the speakers are pretty worthless anyways).
Now the teardown:
해당 답변은 도움이 되었습니까?
Hi @rpsf,
Great work.
How about you create a repair guide and have it posted on ifixit so that others can more easily find it. No doubt they'll thank you for doing so.
Most guides on ifixit are created by users
Also just a point - if you fill the speaker holes with silicone, how's the audio from the speaker going to be heard clearly and not muffled or perhaps maybe not at all if the holes are blocked?
Moderator
24 시간 전: 1
7일 전: 15
30일 전: 54
전체 시간: 701
Hi @reticentrobot ,
have you checked that there is power getting to the camera, you didn't say? Either the power supply or at the power supply wiring at the camera itself?
jayeff 의
@jayeff Not yet, I’ll see if I can figure that out this weekend when I pull it down. I put it through the wall and caulked in the hole, so should be interesting getting it back down to mess with.
Before it finally kicked the bucket it would constantly go offline, and I’d have to unplug it for a few minutes and plug it back in to get it going again. It finally just would no longer reconnect and that’s when I noticed it didn’t even have a power light anymore. I checked the power connection from the camera to the section where it connects to the power cable and that all seemed good, so I’m at the point of having to take it down and figure out if there’s anything to be done or if I have to just replace it. At $200 a pop I’m hoping some sort of repair can be done.
ReticentRobot 의
@jayeff I can confirm that I'm getting power up to the USB female (wall outlet to USB power supply), not sure how to test any further than that. There's also no obvious way to disassemble the camera housing that I see, appears to be glued together.
Found someone who has done it here: https://www.youtube.com/watch?v=iQY4hHRP... - unfortunately I'm about to have a surgery and will lose the use of my left arm for a few weeks, but after I recover from that I'll take it apart and see if I can see anything that jumps out at me as the issue.
ReticentRobot 의
