주요 콘텐츠로 건너뛰기
모델 A1419 / EMC 2806 / Late 2014 또는 Mid 2015. 3.3 또는 3.5 GHz Core i5 또는 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 또는 3.5 GHz Core i5 또는 4.0 GHz Core i7 (iMac17,1) 모두 Retina 5K 화면 장착
A1419 No Diagonostic LED after NVME SSD replacement
Hello,
Recently I replaced the NVME SSD in A1419 iMac.
Unfortunately, it did not turning on after doing that. I replaced the new PSU, but the same situation. It seems PSU is OK.
AC-DC connector, J600 #4~6, #10~12 are 12V. But 4 diagonostic LEDs in logic board are not turning on.
What shall I do check for the first time?
I want to repair by myself… but not board view file for this model. Please let me know the solution and share the borad view file, if you have.
Thank you!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
I would remove the drive you put in it’s likely bad or shorted out.
Carefully plug things back together without the drive and any adapter does the system boot up now?
If it does then you need to replace the drive elements. I would recommend going with a better drive like OWC Aura Pro X2 SSD
Replace or upgrade the PCIe solid-state drive in a variety of Macs. 이미지
제품
OWC Aura Pro X2 SSD
$199.99
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Thanks, DAN!
I removed the SSD, and the same result.
SSD was used in A1502 MBP...
It seems logic board issue, I guess...
@hongabee - You do need to be careful on what you plug in! Take the time to review this great guide The Ultimate Guide to Apple’s Proprietary SSDs Apple has used a few different SSD interfaces so you got to be careful to install the correct one. Make sure the SSD you used is the correct one for your iMac
댓글 달기
답변을 추가하세요
HG Jung 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 141
