주요 콘텐츠로 건너뛰기
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
129 질문 전체 보기
After removing the screen, how to replace the headphone jack?
I need to replace the headphone jack on my 12.9” 1st gen iPad pro. I found that ifixit has the tools and replacement parts, but I can’t find a guide to do it. Is there another device that has a similar guide so I can piece together what I need to do? Is it as simple as replacing the component after the display has been removed? Any guidance would be useful. Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hey,
The headphone jack is on the top left corner of the iPad and you need to remove 3 screws to remove the jack and then all you need is a replacement jack to fix it back up! To remove the connector side of thing first you need to remove the EMI Shielding as mentioned in the iFixit guide in step 10 and then you need to disconnect the headphone jack cable! Take a look at step 11 in the iFixit guide as it will help you in locating the headphone jack connector :D
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Thank you very much!
You're welcome :D, Glad I could help!
댓글 달기
귀하의 답변을 추가하세요
Kevin Roe 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 24
