주요 콘텐츠로 건너뛰기
듀얼 마이크와 802.11ac Wi-Fi 연결 기능을 갖춘 Apple MacBook Air 중 더 작은 노트북.
149 질문 전체 보기
Where can I buy a PCIe to USB Adaptor?
My 11” MacBook Air (2013) recently died and I have opened it up and removed the blade SSD.
Beyond buying an older MacBook Air and connecting the SSD into it (I don't have the money for that), does anyone recommend any USB adaptors I can connect it to?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
First Apple uses a custom SSD so you need a special case to hold it: OWC Envoy Pro Portable, Bus-Powered USB 3.0 Storage Enclosure for select Apple Flash SSDs from most 2013 to 2015 Mac Models.
Reference: The Ultimate Guide to Apple’s Proprietary SSDs
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
AMZ has a number of options. Aliexpress also has a lot if you can wait for it.
해당 답변은 도움이 되었습니까?
점수 -1
댓글 4개:
Thank you for your response. Are you able to provide a link to the product page?
Just search for "nvme to usb" == Since I am not an Apple tech I can't vouch for the fact that the RAM is a std NVMe format. Can't see why it wouldn't be, BUT
@ruggb - Sorry not so simple! Apple did their own thing! You need the correct interface, the M.2 interface is very different. Read the links I posted.
Think of it this way a US power plug won't work in the UK and most of Europe without an adaptor! And you still have to deal with the voltage difference.
Of course they did their own thing, so they can charge more money. That is a primary reason I am a Windows tech. Not saying it is perfect, but I have a big problem with vendors who sell things for 3x what it is worth
댓글 달기
귀하의 답변을 추가하세요
Joshua Gershinson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 40
