주요 콘텐츠로 건너뛰기
Model A1989, EMC 3358. A refresh of the existing design, with updated processor options and a change to the keyboard materials. Available in Silver and Space Gray. Released in May 2019.
134 질문 전체 보기
Replaced screen: Max brightness diminishes after boot
Hi, I just replaced the screen of my macbook pro with a new screen. The problem is that the max brightness is much lower than before and expected. I tried resetting my NVRAM and SMC, and once I reset my NVRAM, the Apple logo appears fully bright for 5 seconds, before something occurs (maybe software side?) and the max brightness decreases by around 50%-80%. A connected monitor maintains the correct full brightness level. Is this some bullshit Apple is pulling by placing software into the retina screens? Does anyone have any clues on how to solve this problem? It is most definitely 50-80% dimmer than before, so don’t tell me to go into a dark room lol.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Can you verify that you installed a 2018-2019 display? If you check here they mention the following: “2017 Screen will work on 2018 model but it will glitch during boot + no truetone.” That sounds similar to your symptoms. Otherwise I would be inclined to think the display you got has a defect.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Hi, Thanks, I looked it up and Im pretty sure I installed a screen from 1 year in the future. $@$* happens lol.
Even you installed a 2018-2019 display, you still can not use the truetone, because Apple blocks the function except you fix the Mac in Apple Store or 3rd part authorized service provider. They will use an internal fix tool to restore truetone.
So, I think you can check the settings of the display is right firstly, then check the connector of the display or have a try re-connect the cable.
댓글 달기
귀하의 답변을 추가하세요
Keith Orange 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 19
30일 전: 67
전체 시간: 1,683
