주요 콘텐츠로 건너뛰기
{A1706 / EMC 3071}—2017년 6월 출시, 이 MacBook Pro 13”는 Kaby Lake 프로세서 최대 3.5 GHz Core i7 및 Turbo Boost 최대 4.0 GHz 포함.
276 질문 전체 보기
Very slow after trackpad install. Trackpad not working or clicking.
Dear all,
I replaced the battery on an A1708 macbook pro. Afterwards I figured out how I ruined the trackpad while removing the battery adhesive. At first I thought I only damaged the cable. But I scraped off smd components from the trackpad.
Because I suddenly had to order a new trackpad, I put everything together without the cable attached so at least you can work with it with an external keyboard and mouse.
When starting, everything is extremely slow when logging in. Vent is on 100%. Top bar remains transparent.
When I got the trackpad I installed everything the way it should be. I did not put everything completely together. I wanted to test it's function first. The trackpad mouse worked, keyboard worked. The mouse click however did not work. I removed the adhesive of the cable and stuck it to the battery. Put everything back together.
Now I hoped everything magically would turn normal. But alas.. the keyboard works but now the mouse does not work. Also macOS is still extremely slow to the point you cannot work with it.
What happened? And how can I fix it.
Thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
This is the expected behavior! Your system is in CPU Safe Mode!
This is when your systems SMC lowers the CPU’s clocking and pushes the fans RPM so you don’t damage your logic board.
Once the touchpad is reconnected SMC will regain access to the sensors you disconnected.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Everything is connected properly now, yet trackpad is still unresponsive. And not 'clicking'.
Do I just turn on, login and let the macbook run for an hour hoping it will go out of safe mode?
Or as I read somewhere that resetting the SMC will fix these issues?
@morteus - New unit? Yes SMC reset will be need. I would run the onboard diagnostics as you may have another problem as well.
댓글 달기
귀하의 답변을 추가하세요
Pascal 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 11
전체 시간: 208
