주요 콘텐츠로 건너뛰기
Microsoft's third-generation Xbox game console, released November 22, 2013.
727 질문 전체 보기
Heavily damaged Xbox One - broken connector on Front Board.
Trying to nurse back to health a heavily damage Xbox One. I have some success but will not power up.
There is broken connector on the Front Board that connects from the wifi board to front board. I tried to solder the connector back on with bad results. How does this connector effect the workings the buttons on front panel? Does it mean that controls will not work?
I am also going to remove and check under the heat sink for damage as it is damaged as well. Though there is no signs of damage to motherboard on either side.
Update (06/01/2021)
Still no real answer on front board connection. I did manage to take the heat sink off to see if there was any damage underneath. Thankfully nothing I could see … even with a magnifying glass. I did manage to ‘hammer’ out the heat sink using a strip of thick plastic. LIGHTLY tapping with the hammer.
I managed to get it relatively flat and reinstalled with fresh heat sink compound. Only the word on what function the connector has and possible work around before I can test once again.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Check out game console repair legion on Facebook. A lot of console techs on it.
This is not really an answer is it.
댓글 달기
답변 1개
가장 유용한 답변
An RF connector should not impact power-up in any way. If the console does not power up, you have a big problem.
Judging from the heat sink, I’d say the CPU has massive soldering failures underneath, it’s not worth repairing.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Michael Eh 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 8
전체 시간: 307
