주요 콘텐츠로 건너뛰기
The TI-Nspire CX handheld features a full-color, backlit screen, thin sleek design and includes TI-Nspire rechargeable battery.
35 질문 전체 보기
White screen when I tried to run pokemon emerald on a Ti Nspire CX II
When I tried to run pokemon emerald on a Ti Nspire CX II, it just gives me a white screen and I don’t know the reason behind it. I reset my calculator multiple times. I have endless installed. It worked one thing and after that, it never worked and whenever I tried to run it, it just gives me a white screen. Can someone show me how to fix it or teach me? That would be appreciated!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
To be clear, your calculator is functioning normally as a calculator, it just won't run Pokémon?
If so, try moving some files from your RAM to your Archive. Unfortunately I don't know much about the Nspire calculators, so you'll be better off posting a question like this over on TI-Planet where they specialize in all things Nspire. Although the site is in French, the members will be happy to help you in English if you need. Here's the best place to post your question: https://tiplanet.org/forum/viewforum.php...
If you can't get the calculator working normally, try following this guide: https://tiplanet.org/forum/viewtopic.php...
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I was able to run pokemon emerald for a bit. After a while, when I tried to run pokemon emerald it just gave me a white screen. I am also able to run pokemon silver.
댓글 달기
귀하의 답변을 추가하세요
DAVID ZHENG 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 298
