주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
Why does no home button work after battery replacement?
So I replaced the battery on this black iphone 7, 32GB. It got a replacement screen some time ago, in case that matters. When I closed the iPhone back up, the home button didn’t work. Just wouldn’t click. I have another fully functioning iPhone 7 at home, so i got to testing. I took a look at the flex cables, tried another home button, even tried another display/home button combo (which was working in another phone) but the home button still wouldn’t work. I even tried another working taptic engine (even though a defective taptic engine could not really be the reason) It just doesn’t react to presses. Touch ID also doesn’t work (but i don’t get the “touch id couldn’t be activated” message!) and double tapping the home button to reach the top of the screen also doesn’t do anything. Restarting/Hard Restarting the phone also doesn’t help. The flex connectors on the logic board also don’t look damaged, i even took pictures but couldn’t see any bent pins etc. What on earth could I have damaged inside the phone that causes no home button to work?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
You need to try a new display with the original home button, I don’t see you trying this combination.
Replacement button won’t work whatsoever, the flex cable on the display is super easy to damage and you can’t tell by just looking.
It’s most likely that you have the display cable damaged and without trying a good display with the original button, you won’t know.
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
But I tested another working original home button from another iPhone, why didn’t that work? I could see touch ID not working that way, but the normal click should work, right?
@Johnny Wedel No, starting with iPhone 7, replacement button won’t work whatsoever. There is no clicking in the button itself, it is just a force sensor and without pairing, force data won't relay.
Ohhhhh okay thanks a lot. I’m going to try that. I hope i didn’t somehow damage the home button itself, a display would be a lot easier to replace.
It worked just fine, i even saw the damage on the flex now taking a close look at it.
댓글 달기
귀하의 답변을 추가하세요
Johnny Wedel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 83
