A Samsung Series 3 PC, the NP300E5C-A09US is a 15'' laptop with a 1366x768 screen resolution. It is a great choice for anyone looking for a lightweight, yet powerful portable computer.
이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
Hi,
Can you get into BIOS by tapping the F2 key several times just after startup?
Check if the SSD appears in the Boot priority order menu section of BIOS.
Also with some Samsung laptops if you wish to boot with a USB you need to disable "Fast BIOS mode" in BIOS > Advanced because if it is enabled it doesn't check the USB port on startup. It skips over it. Apologies if you knew this already.
Hi,
jayeff 의
