주요 콘텐츠로 건너뛰기
The Shark Rotator NV502 vacuum was made in 2013, weighs 15.5 pounds, and includes a lift away handle. The vacuum can be used on both carpet and hardwood floors.
17 질문 전체 보기
My shark powered lift away won’t turn on
When I turn on my shark lift away, the lights will come on but the vacuum doesn’t do anything. It doesn’t make any noise, the brush doesn’t move but the lights do come on very bright. Any suggestions of what could be wrong?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
@skelly64 use something like this video to work on your vacuum. Since your lights are bright, and you seem to think brighter than usual, I would suggest that you use a multimeter and check if there is actually power going to the motor. Once you have your vacuum partially disassembled it might help you out if you post pictures so we can continue to guide you 기존 질문에 이미지 추가하기 All you should need for this check would be your basic hand tools (screwdrivers etc.) and a run of the mill multimeter. Nothing fancy.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
motor bad, brushes jammed causing the overload to trip, or an interlock switch open because it is bad or the parts are not assembled correctly.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Sandy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 30
30일 전: 137
전체 시간: 1,458
