주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Why is screen not working
why is my fitbit inspire screen not working
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 6
댓글 9개
I want to repair my smart watch
의 공유
Scrreen is up down and screen is deem
=== Update (09/15/2022) ===
Please answer service center
의 공유
My whach is garantin is expiry what solution
의 공유
I forgot to take my Fitbit watch off before getting into the hot tub and it got wet and it isn’t coming on since I have had it for a long time
의 공유
मेरी घड़ी चालू नहीं हो रही है और न ही चार्ज हो रही है मेरी घड़ी चालू नहीं हो रही है और न ही चार्ज हो रही है My watch is not turning on or charging please help
의 공유
댓글 4개 더보기
댓글 달기
답변 5개
가장 유용한 답변
Shout out to Chantelle - changing the clock face in the app worked for me too. Screen was black on charger and off charger. It was still syncing with the app so that was working. Tried force restart and got nothing- held the two buttons while it was on the charger for a full minute and nothing. Confirmed it wasn’t in water lock mode by double tapping the screen a dozen times.
Changing the clock face in the app- boom screen is back and buttons working again. Kinda stupid but hopefully this helps someone.
이 답변이 도움이 되었나요?
점수 5
댓글 4개:
changing the clock face helped me too!!
I am not impressed by this equipment. My previous once lasted years without issues!
의 공유
Thank you so much, this worked for me.
의 공유
Thank you. This worked for me too.
의 공유
how change clock face
의 공유
댓글 달기
First of all, charge it up to 100% If your Fitbit is not fully charged, place it on its charger first and wait for it to reach full capacity. It's better to charge your Fitbit through a wall outlet than your computer's USB ports - this is due to certain limitations in your computer's port wattage.
Once you've fully charged your Fitbit, try to see if the screen now appears and is responsive.
Make sure your Fitbit isn't in water lock mode
Some Fitbits include a water lock mode, which prevents the screen and buttons from responding to touches and swipes. To turn off the water lock, dry your Fitbit off, then double-tap your screen (Inspire and Luxe) or long-press the side button (Sense and Versa 3) to turn off its water lock. You may have to repeat this several times to unlock it.
Remove any case or screen protector
It is best to remove any case or screen protector to make sure it does not block the ambient light sensor. Your Fitbit's ambient light sensor looks like a black dot on the side of your Fitbit device. If this is blocked, your screen will usually go dark automatically.
Check your screen brightness settings
Oftentimes, we need to adjust the brightness of our Fitbit's screen. We suggest you go to a dark room or wait until dark, then take a look at your Fitbit.
Try to restart
If you see a black or blank screen on your Fitbit, the first thing to try is a forced restart or restart (also known as a long restart.)
Restarting your Fitbit forces it to restart - and often fixes issues like a black, blank, or unresponsive device.
How you restart or force restart depends on your model, so it's best to consult your Fitbit user manual.
이 답변이 도움이 되었나요?
점수 3
댓글 4개:
I dont need to see my fitbit working n a dark roo
I need to be able to see it while I am outside working out or on a hike
Which it is not bright enough, when outside
의 공유
Have tried the suggested reboot about 10 times. Screen still blank, but Fitbit still working because info in app continues to update.
의 공유
My Fitbit charge 5 , isn’t working, i see the logo , and the next screen is not moving when i slide in any direction
의 공유
My Fitbit charge 3 looks okay when plugged into its charging cradle but when I take it off the cradle the screen is completely black and button on side doesn't work? Any ideas to help? Thanks Theresa
의 공유
댓글 달기
I was able to get mine back on by changing the clock face in the app. After swimming it stays in water lock….
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Thank you for your very clear instructions but unfortunately it’s still not working. However Fitbit help are sending me a replacement free of charge under the guarantee. Excellent service
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I can notgey my fitbit light up on settings
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
raylaver 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 6
지난 7일: 54
지난 30일: 308
전체 시간: 55,800
