Why won't the claw move left to right, everything else works.
the claw will go up and down and open and go back and forth, but not left to right. there are no wires that are cut anywhere.
좋은 질문 입니까?
좋은 질문 입니까?
@gambit2115 I suggest that you take a look at the stepper motor on top of the claw itself. Check this guide The Claw "Claw" Replacement and remove the cover from the mechanism the drives the sled. Take a good look at the wiring and with a multimeter see if the motor gets power when you move the controller. If it does you pretty much know it could be the motor. If it does not you will have to check the circuit board and the controller. Use this guide The Claw Circuit Board Replacement for that. Check the limit switches on wither side of the gantry as well to make sure that those are working and not stuck in the off position. Do not forget to post plenty of pictures on what you see with your QUESTION. That way we see what you see and can follow you along your repair and guide you further if possible.
안내서
난이도:
아주 쉬움
2 - 5 minutes
안내서
난이도:
운영
10 - 15 minutes
안내서
난이도:
운영
20 - 30 minutes
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 21
30일 전: 97
전체 시간: 1,929
