주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Claw Circuit Board Replacement
필요한 것
    1. The Claw Circuit Board Replacement, Bottom Cover: 1 단계, 이미지 1개 중 1개
      • Place The Claw in upright position with controls facing you.
      댓글 쓰기
    2. The Claw Circuit Board Replacement: 2 단계, 이미지 1개 중 1개
      • Gently flip The Claw machine upside down with the controls facing you.
      댓글 쓰기
    3. The Claw Circuit Board Replacement: 3 단계, 이미지 1개 중 1개
      • Remove all ten screws from the bottom cover using a Phillips #1 screwdriver.
      • You will need a screwdriver with a long thin neck to fit in the screw holes.
      댓글 쓰기
    4. The Claw Circuit Board Replacement: 4 단계, 이미지 2개 중 1개 The Claw Circuit Board Replacement: 4 단계, 이미지 2개 중 2개
      • Slide the bottom cover off to the side.
      • Do not completely remove bottom cover as it is still connected to wires.
      댓글 쓰기
    5. The Claw Circuit Board Replacement: 5 단계, 이미지 1개 중 1개
      • Complete removal of the bottom cover is not necessary, however if you feel you need to take the cover completely off the machine to complete your task it can be done by the following process.
      • You will need to cut the two green wires attached to the music player.
      • Then you will need to cut the white wire that leads to the battery compartment.
      • Finally you will need to cut the black wire leading to the battery compartment as well.
      • The complete removal of the bottom cover requires the cutting and soldering of wires. For help with soldering reference: 연결부 납땜 및 납제거 방법.
      댓글 쓰기
    1. The Claw Circuit Board Replacement, Circuit Board: 6 단계, 이미지 1개 중 1개
      • Once you have removed the bottom cover you should have clear access to the circuit board.
      • Locate the circuit board in the bottom of The Claw machine.
      댓글 쓰기
    2. The Claw Circuit Board Replacement: 7 단계, 이미지 1개 중 1개
      • Locate the screws that hold the circuit board in place.
      댓글 쓰기
    3. The Claw Circuit Board Replacement: 8 단계, 이미지 1개 중 1개
      • Be sure to turn off the device and remove the batteries before reaching into the device with your hands or any metal tools.
      • Using a Phillips #1 screwdriver, remove the four 6mm that hold the circuit board in place.
      • You will also need to cut all of the wires leading to the circuit board to completely remove it.
      댓글 쓰기
    4. The Claw Circuit Board Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the circuit board.
      • The removal of the circuit board requires the cutting of existing wires and soldering new wires to the new board. For help with soldering reference: 연결부 납땜 및 납제거 방법.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Alain Pierre
회원 가입일: 03/22/16
1,188 평판
안내서 9개를 작성함
UMass Dartmouth, Team 4-8, Catania Spring 2016 UMass Dartmouth, Team 4-8, Catania Spring 2016 회원
UMASSD-CATANIA-S16S4G8
3 회원들
안내서 54개를 작성함
9가이드 댓글
I accidentally cut the wires where the motors are and now can not figure out which go where, is there a diagram or drawling of where each wire goes?
Dyn4mic Universe - 답글 공유
Did you ever find a diagram for this? I would like to have one also….
Nathan Riffel - 답글 공유
Does anybody know where to get the replacement switches for these?
Bill B. - 답글 공유
Same. I am in need of the replacements as well.
Allison Rousseau - 답글 공유
Me too. L/R switch doesn't work need to replace it.
Johnny Annon - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 17
지난 30일: 69
전체 시간: 7,872
