주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
1049 질문 전체 보기
Is it ok to reassemble the home button without the "spring contact"?
I followed the iFixIt guide to replace the screen on my iPhone SE (1st generation): iPhone SE 스크린 교체
Step 23 of the guide mentions a "spring contact backing" part which is supposed to be screwed in between the home button cable and the screen.
I spent over an hour trying to screw it in between the home button cable and the screen, and every time I started turning the captive screw, it moved out of position. Looking at the comments on Step 23, I am not the only person who found it to be a frustrating and impossible task. I finally gave up and just screwed the home button cable to the screen without the spring contact backing.
The phone and home button seem to be working fine without the spring contact backing. But could there be any long term consequences without it? Surely Apple had a reason to put the spring contact backing in between the home button cable and the screen.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Most people seem to not have any issues with not having the spring contact in there, and if your device seems to work fine without it, then it shouldn’t be a long term issue. If it was going to cause any major issues you would likely know almost immediately when trying to use the device or the home button.
Keep in mind though that if it does start to act funny in the future(ghost touching/clicking of home button) then this will almost definitely be the reason why.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
delerious 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 33
