주요 콘텐츠로 건너뛰기
Repair guides and support for your Samsung TV.
2614 질문 전체 보기
watching TV then a loud pop and TV quit playing.
Same thing was watching TV then a loud pop and TV quit playing. Using firestick. TV model number is LN46D550K1FXZA serial number is Z315CBB802141Y version SQ03
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@snakebstr unplug your TV and unplug all inputs. Remove the back cover and check the power board for any obviously damaged looking components. This can be caused by a bad capacitor as well as a blown rectifier. If there is nothing obvious you could use a multimeter and check the voltages to the power board as well as the connector the ribbon cable to the main board. See what voltages you get on that. Let us know what you find. Post some pictures of your boards with your question so that we can see what you see. 기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
David Evans 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 18
