주요 콘텐츠로 건너뛰기
MacBook 제품군은 2006년 5월에 처음 소개되었으며 Apple의 가정용 노트북 iBook을 대체하였습니다.
3786 질문 전체 보기
The coin lock cap broke off and stripped
The coin operated battery lock cap broke off on my MacBook and the lock itself is stripped.what should i do? The battery doesnt lock now so i have to tape it to the case..plz help
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
Can you post a picture of how exactly it's broken?
댓글 달기
답변 3개
가장 유용한 답변
If the switch is stripped and can't be operated with a coin anymore, you can try using superglue (to attach a coin or something else to grab onto) and get enough leverage to twist it back into the locked position.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
The battery lock mechanism is part of the MacBook bottom case and it can't be swapped. You need to replace the bottom case. Try to find a used bottom case in good condition.
http://www.blogcdn.com/www.joystiq.com/m...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi
I've got a similar problem except the lock pinged off whilst in the locked position so I can't actually take the battery out!! To add insult to injury, this only happened when I was about to replace the battery which no longer charges!
Is there a way of removing the bottom case without taking the battery out?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
sanane 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 5,139
