My tv screen has just start going black but I still have sound
I can’t find the power button on the tv to reset it
좋은 질문입니까?
좋은 질문입니까?
You need to do a flashlight test, Turn it on and hold a flashlight up to the screen. If you can see an image then either the power supply board or the backlights are bad.
If you see an image then disconnect the cable going from the power supply board to the main board, If the back lights come on then you need to replace the board. If not then its most likely the backlights need replaced.
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 0
지난 30일: 9
전체 시간: 203
댓글 4개
What is the model of your TV? If you shine a flashlight on the TV screen while the TV is on, do you see a faint picture?
Andrew S 의
can you please tell is what device(s) you are attempting to use your TV with
[deleted] 의
Hi, in my case I can see a faint imagen when pointing a flash light to the screen anda I can perfectly hear the sound
Mauricio 의
My set is a Hitachi 42HYT42U and when turned on works perfectly for some time and then the picture goes off but the sound continues. If the set is turned off and immediately turned back on, the set works perfectly again for some time again.
Bob Brown 의
