주요 콘텐츠로 건너뛰기
Hybrid laptop/tablet manufactured by Microsoft. Released October 2015. Model 1703.
83 질문 전체 보기
Surface Book 1/2 13.5" Adhesive Strips this for screen replacement?
Surface Book 1/2 13.5" Adhesive Strips - iFixit for screen replacement or battery replacement ?
Surface Book 1/2 13.5" Adhesive Strips 이미지
상품
$13.99
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 해법
From the description, says digitizer screen to frame. As for batteries, I typically use double sided tesa tape. I’ve done surface pros using tesa tape and it works out just fine btw.
This adhesive film secures the front glass digitizer screen to the frame of your Microsoft Surface Pro 1/2 13.5".
Complete your replacement of the front glass with new adhesive. There is no measuring, cutting, trimming, or shaping needed with these custom cut adhesive strips.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
The battery adhesive is so strong that even if you pull the battery off, you can reuse them as long as you don’t tear or wrinkle them.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thanks, it`s very helpful.
댓글 달기
Thanks for the answer
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Tandang Sugistiawan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 214
