Backlight is flickering, possibly damaged internals?
I power on my Chromebook, it seems fine at the bright white boot screen, but once I get to something dimmer (Discord window, wallpaper, anything dimmer than pure white), I notice a rapid flicker on the screen. The backlight never completely dies out, but the flickering is an eye strain and a huge annoyance. I already tried this guide in an attempt to get at the ribbon cable and nudge it back into place: Lenovo N22 Chromebook Screen Replacement
But now…I think I've done something horribly wrong. I tried to follow these steps, and made it as far as step 2. I have an N22 Touch rather than just the N22, but I figured that besides the touch screen they would be pretty much the same on the inside. But once I tried to lift up the keyboard, and felt some resistance, and found that in the top-right corner (by the power button), there appeared to be a piece of metal with a screw attached to the underside of the keyboard. When I tried to loosen this screw, it didn't budge. Possibly stripped? I can't lift the keyboard at all. Help!
좋은 질문 입니까?
댓글 1개
I have this issue too, with a new Chromebook. It was worse on my old one because I dropped the laptop, messing up the screen, so I got the laptop as a replacement. The screen issue used to be so bad my cursor was affected. I removed my extensions, powerwashed and reset ChromeOS settings AND flags to default. The screen improved but the flickering backlight with the cursor (mostly in incognito tabs or anything that isn't white) still happens.
I don't know what to do. I can't replace the screen myself because I'm not good with technology at all, but when I replaced my screen, my webcam quality got messed up and the screen was worse for wear. I just got this laptop last week. I'm so frustrated!
Tia 의
