주요 콘텐츠로 건너뛰기
Samsung에서 제조한 Samsung Galaxy Note 5는 (Note5로 불림) 스타일러스를 탑재한 phablet/패블릿 스타일 휴대폰입니다, 2015년 8월 출시.
271 질문 전체 보기
Black screen and pulsing blue led
I just replaced the battery, and it vibrates when I hold the power button, I don't know if the screen is just broken but want to try other things to see if I can get it to work before replacing it, I just have a pulsing blue led right now and nothing more
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
This can be a rather tricky repair as the mental frame has to get pushed out from the rest of the mid frame which holds the OLED screen and other components. It is very likely that the Oled panel might have sustained damage but I would look closely around the edges or check the connector. If you hear sounds when connecting the charger or when getting calls then it's likely a display issue. If you don't then it could be the contacts for the power button arnt touching the motherboard.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Peter Griffin115 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 12
전체 시간: 82
