주요 콘텐츠로 건너뛰기
The Ford Fiesta is a subcompact car (B-segment in Europe) manufactured by the Ford Motor Company since 1976.
23 질문 전체 보기
My lock fob has suddenly stopped working on my Ford Fiesta 2012 plate
My key fob has stopped working on my fiesta. I can use the key to manually lock and unlock the doors.
can’t change battery as it’s a sealed unit
Update (09/02/2021)
her is a picture of my fob
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Hi @joys2121 ,
Here’s a video that shows how to open your key fob to replace the battery.
The battery model used is a CR2032. It is a common battery available most everywhere e.g. supermarkets.
Note: Ensure that you insert the new battery the same way as the original. There is a +ve symbol marked on the battery so that you know which way it goes into the battery holder.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thank you so much for your help changed battery easily with the help of you tube had to re program after changing the battery but google helped with that
댓글 달기
가장 유용한 답변
Hi @joyspurrier, can you attach a photo of the key fob? (Click here for directions on how to add photos to your post.)
Even with the “sealed” devices you can usually get into them with a spudger (or a guitar pick, credit card, or flat head screwdriver). Once you’re in, you should be able to swap out the battery. This guide has a quick video example of using the key to open their fob.
Hope this helps!
iFixit 이미지
안내서
기존 질문에 이미지 추가하기
난이도:
아주 쉬움
2 - 5 minutes
2009-2015 Toyota Prius Key Fob Battery 이미지
안내서
2009-2015 Toyota Prius Key Fob Battery Replacement
난이도:
아주 쉬움
2 minutes
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
joy s 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 22
전체 시간: 1,034
