주요 콘텐츠로 건너뛰기
The Razer Blade Stealth is a gaming laptop with a 13.3 inch wide screen. The laptop features 16 GB of RAM and an Intel Core i7 CPU. It comes in Space Grey and Mercury White.
3 질문 전체 보기
New battery only works while plugged in
I just replaced my battery in my razer blade stealth and it works fine while plugged in but says charging and stuck at 97% and when I unplug it it turns off immediately and won't turn on while unplugged. The battery is brand new. The old one was fairly bloated.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 3개
does the laptop power on without a battery?
@logixal yea it will power on without the battery connected
Exact same problem!
댓글 달기
답변 1개
가장 유용한 답변
@riveteer I am certain you double-checked your work and made sure that your connectors are all properly seated and that there are no issues like bend pins etc. with those. I would contact the seller and replace the battery once more just to rule it out as the culprit.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Yea thanks. I did look around more today and was looking at the connector for the original battery and the one I bought from ifixit had a poor connector. I bought another and plan on returning the one I got. Thanks
댓글 달기
답변을 추가하세요
Jack Kuckhahn 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 4
전체 시간: 786
