주요 콘텐츠로 건너뛰기
Repair guides and support for televisions manufactured by Sony.
748 질문 전체 보기
Back Panel Removal on a Sony XBR65X800h
This is a unique set in regards to the back panel. It is a full rear panel, top to bottom. Minimal screws on the bottom and none on the top similar to Samsung’s screwless back panel. How does this come off? Does it pry off like the Samsung TV’s? To be clear this is not the half back panel that the slim Sony’s have. This is a full back panel. Unique to this size of tv. The image above is the actual set.
I removed 5 screws. 4 where the wall mount would screw into the set and one by the power plug.
Looks like the bottom is held in with plastic clips which I have released. The sides and top all seem to fit into the front frame all the way around so no way of hitting the bottom to have it slide up. Maybe the front frame has to come off first? The rear panel is connected to the front panel frame.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
선택된 답변
The back is clipped into the frame along the right, left and top. I removed it after removing the 5 screws by pulling up on left side then right side and then lifting the back panel up the top unclipped itself. Pictures show the clip on the back panel and where it fits into the frame.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
Hey James can you give more details,
I followed everything you say and I still can't get it off.
Where is this picture?
I’m struggling with this as well. I removed all the frame/trim screws hoping that would help but no luck. Next step will be the dremel.
댓글 달기
가장 유용한 답변
This is from another model response, but I suspect it is probably similar. It may also have latches on the bottom
Once you have all the screws out from the back you want to wack the panel from the bottom towards the top of the tv. Essentially there are fixed screws that the back panel is resting on like a picture rests on a screw in the wall. So you want to push it up in the same plane as the tv panel. If you force the back away from the tv you will break those snaps. There are around 4 or 5 screws across the you inside the cover so it can take a lot of controlled force to knock the panel off the screws.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
@netjunky sony has a couple of models that are definitely a PITA for the back cover removal. See if this will help you out.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
This is close. The panel on this set meets the frame all the way around. The set pictured seems to have a 1-2 inch space between the frame and real panel.
댓글 달기
귀하의 답변을 추가하세요
James 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 11
7일 전: 33
30일 전: 155
전체 시간: 6,392
