Kenmore Elite HE5t washing machine F32 and F99 Error Codes
The washer was giving SUD/F35 error. I installed a new CCU and a new Pressure Switch. It immediately gave F32 error at about 7 minutes of starting the wash. If I pull the plug and restart (so that the door will unlock), it gives F99, which goes away if I hit the power button, but F32 comes back in about 7 minutes of starting the wash. I also checked the voltage on PS8 socket pin 1 and 2, and it shows 0.5V when the tub is empty, and when it starts filling, it slowly rises to 3.0V, and then I get F32 error.
The fill, spin, drain seem to work just fine. I checked the pressure sensor tube at the top and it seems fine (although did not check the bottom, as it would require moving the machine). I cleaned the filter to the drain-pump, and checked the pump for any debris.
When I run the diagnosis option 1, it immediately gives F99 error and stops. If I run the Diagnosis Only test (option #2), it cycles through C00 to C04, spends a long time on C04, and then throws F32.
What do you think is the issue? Thanks for your help.
좋은 질문 입니까?
댓글 2개
Hi @noeinstein ,
What is the model number of the washer?
jayeff 의
Hi @jayeff, It's 110.47788800.
No Einstein 의
