주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.0GHz, 2.3GHz, 또는 2.6GHz 쿼드-코어 Intel Core i7 프로세서 (Turbo Boost 최대 3.8GHz).
580 질문 전체 보기
Why is there vertical lines on the left side of screen
There are vertical lines on the left side after a letter opener was closed up in the mac { letter opener in same location , left side near hinge] . Now if I just touch the screen in that lower left screen area . . . the lines will change . common sense tells me this is screen damage . When I touch the screen [ gently ] and putting no pressure on the hinge and any connectors ect. . . the lines change . Is this screen damage or the wires in the hinge ? There is no visible damage to the screen .
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
The LCD panel is a sandwich of two glass plates. the back one is a bit more brittle and often cracks before the top one which you can see. The reason the back plate is more sensitive has to do with the processing it gets. It is etched and plated with metal oxide traces which route in an X-Y structure the signals which turn-on/off the discreet pixels.
So with that understanding the lines you see are the micro fractures within that plate signal pathways so the signals are being interfered with. As you touch or shift the display you are allowing the connections to make and break and depending on what the line was to drive, you’ll see different colors or just black.
Bottomline you need a new display 15” MacBook Pro A1398 Display Assembly, Apple P/N 661-8310. Here’s the guide to put in on MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Thanks for the very good response that and this web site are a real help .
@jmcobuilders - Don't forget to score the answer and accept it - Thanks!
댓글 달기
귀하의 답변을 추가하세요
jimcornish@sbcglobal.net 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 6
전체 시간: 217
