주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement
필요한 것
  1. MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
    댓글 쓰기
  2. MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
    댓글 쓰기
  3. MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement, Battery Connector: 3 단계, 이미지 1개 중 1개
    • Peel back the warning label covering the battery connector.
    댓글 쓰기
  4. MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement: 4 단계, 이미지 2개 중 1개 MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement: 4 단계, 이미지 2개 중 2개
    • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
    • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
    댓글 쓰기
  5. MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement, AirPort/Camera Cable: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board.
    • The cable connection points are fragile. Be careful to lift only on the connector, and not on the socket or cable.
    • To reconnect, align the connector carefully into position over the socket, and press it down firmly with the flat of your spudger.
    댓글 쓰기
  6. MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement: 6 단계, 이미지 1개 중 1개
    • Use the tip of a spudger to push the camera cable's plug toward the fan and out of its socket on the logic board.
    • The plug in the photo has six connections, but some models have twelve connections. The process of removing the plug from its socket is the same for both.
    • If the camera cable's plug won't come easily out of its socket on the logic board, fold back the rubber cover over the fan to gain access to the cable, then gently pull on the cable while using the spudger to gently push the plug out of its socket.
    • Be sure to push parallel to the board, first on one side, then the other, to slowly "walk" the plug out of its socket. Do not pry up, or you will damage the socket.
    댓글 쓰기
  7. MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement: 7 단계, 이미지 3개 중 1개 MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement: 7 단계, 이미지 3개 중 2개 MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement: 7 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger underneath the rubber heat sink cover on the right fan.
    • Slide the spudger underneath the length of the cover, releasing the adhesive.
    • Lift the cover and flip it back so that you can access the cables underneath.
    댓글 쓰기
  8. MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement: 8 단계, 이미지 3개 중 1개 MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement: 8 단계, 이미지 3개 중 2개 MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement: 8 단계, 이미지 3개 중 3개
    • Use your fingers to pull the AirPort/Camera cables up off the fan.
    • The cables are adhered to the fan, so peel them up carefully to avoid damaging them.
    • Carefully de-route the cables from the plastic cable guide.
    댓글 쓰기
  9. MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement, Display Assembly: 9 단계, 이미지 2개 중 1개 MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement, Display Assembly: 9 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry off the two rubber hinge covers, one from each end of the device.
    댓글 쓰기
  10. MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement: 10 단계, 이미지 2개 중 1개 MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the two 3.1 mm T5 Torx screws securing the aluminum hinge covers to the upper case.
    • Remove the two aluminum hinge brackets from the MacBook Pro.
    댓글 쓰기
  11. MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement: 11 단계, 이미지 3개 중 1개 MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement: 11 단계, 이미지 3개 중 2개 MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement: 11 단계, 이미지 3개 중 3개
    • Use the tip of a spudger to pry the display data cable lock and rotate it toward the DC-In side of the computer.
    • Pull the display data cable straight out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
    댓글 쓰기
  12. MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement: 12 단계, 이미지 1개 중 1개
    • Remove four out of the six 5.3 mm T8 Torx screws securing the display to the upper case.
    • We purposely have you leave one screw attaching the display to the upper case to aid in future steps.
    • When reassembling, make sure that the screws go through the two grounding loops on the webcam/airport cable.
    댓글 쓰기
  13. MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement: 13 단계, 이미지 1개 중 1개
    • Open the MacBook Pro approximately 110 degrees, and place it sideways on the table, as shown.
    • While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the lower (closer to the table) display bracket.
    댓글 쓰기
  14. MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement: 14 단계, 이미지 1개 중 1개
    • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
    • While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the upper display bracket.
    댓글 쓰기
  15. MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement: 15 단계, 이미지 3개 중 1개 MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement: 15 단계, 이미지 3개 중 2개 MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement: 15 단계, 이미지 3개 중 3개
    • Grip both halves of the device, one in each hand.
    • Gently push forward on the bottom half of the device to detach it from the display assembly.
    • Carefully set each component aside, making sure to set down the lower half keyboard-side down.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 139명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Andrew Optimus Goldheart
회원 가입일: 10/17/09
515,338 평판
안내서 407개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 30,155개를 작성함
21가이드 댓글
I was a bit scared to do this... But it was actually not that hard... And I had no issues whatsoever. Thank you so much! You saved my ass hahaha.
Jasmine Shoja Ardalan - 답글 공유
Worked perfectly for me. Thanks for the guide!
Mike Lucas - 답글 공유
I have limited computer repair experience but I found this repair very easy and straightforward to do. If you're careful with the cables and don't force them you shouldn't have any problems! Thank you ifixit!
Kyle - 답글 공유
Other iFixit guides worked great for me. So when my Macbook pro 15" retina late 2013 got a cracked display I bought a new one and tried assembling it with this guide. I tried this so many times, and even bought a couple of displays (both are supposed to have matched the model number of my laptop), but it didn't work for either of them. My old display, which was cracked, comes on, but the new ones I bought don't come on when I boot the computer. I've also tried those weird key combinations that they suggest for fixing a black screen elsewhere on the web. I am at my wit's end.
Ann Marie - 답글 공유
But I might have gotten the wrong year :( Apparently the macbookpro I have is 2015, not 2013.
Ann Marie - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 29
지난 30일: 188
전체 시간: 131,149
