주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1863, A1905. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
873 질문 전체 보기
Rear camera not working after battery replacement
(iOS 13.5, jailbroken) Recently replaced the battery and now the rear camera just shows a black screen, when I take a photo of with the black screen the camera freezes and I have to close and reopen the camera, tried in a jailbroken and unjailbroken state
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개:
I recent had the battery in my iPhone 7 replaced and my rear camera was only showing black screen, but I could take a selfie. I waited one day later, reset camera settings and powered down, held power button for 10-15 seconds, beat phone lightly on countertop, powered back on, camera started back working. Can take photos again☺☺I'm a happy camper
just yesterday 8th August,2023 i went to change my iphone 8plus battery and when i opened my back it went blank
댓글 달기
답변 2개
Have you gone back inside the phone since the repair to look at the connections and the hardware of the cameras? The cameras may not be well connected to the main board. I’ve seen this issue on iPhone 8s in the past that needed new camera sensors, but if it happened after a repair, something may have just been knocked out of place. Disconnect the camera sensors (they’re under a metal plate held by two Y screws), lightly clean the contacts with iso alcohol and a soft toothbrush if you wanna be safe, and then reconnect the cameras once the alcohol is dry, if you used it.
Don’t reseal the front display until you can confirm that everything works correctly.
If you already did this and still have this issue, inspect the cameras and their cables for damage. If you open the camera app and try portrait or time lapse, do you see anything? Does the front camera still work?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Was a software issue, working after force reset- volume up, volume down, hold power button 10 seconds
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Callum higgins 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 45
30일 전: 182
전체 시간: 3,633
