주요 콘텐츠로 건너뛰기
모델 A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, 또는 2.4 GHz Core 2 Duo 프로세서
1203 질문 전체 보기
Pulsating Sleep Light, But Computer Won't Start
My computer stopped working after a coffee spill. So, I took the logic board out, then cleaned it and baked it.
I put the Macbook Core 2 Duo (early 2009) back to gether, and plugged the power adapter to it. Immediately the white light on the front of the machine started to pulsate (which it didn't do before).
I can also hold the power button down to 5 seconds and the pulsating will stop and vice versa.
Is there anything else I can try or is my macbook D.O.A?
Thanks for any and all help :)
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
가장 유용한 답변
You could try a SMC reset. Instructions here. Good luck.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Ok thanks, tried the SMC reset, no luck.
Bummer. I'd take the whole thing apart again and reconnect everything. How did you clean the LB? I use 99% proof isopropanol and dry very thoughly. Perhaps you've been too quick. Give the LB a good look with a strong magnifier to check for soiled/burnt components.
댓글 달기
귀하의 답변을 추가하세요
Paul 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 552
