The power switch does not work.
Hello
I am a macpro 3.1 user.
The power switch didn't work normally.
When I press it this time, the switch part flashes and the power does not come on.
Which part is the problem?
좋은 질문 입니까?
Hello
좋은 질문 입니까?
@joyy3 check the diagnostic LED’s
Logic Board Diagnostic LEDs
The Mac Pro logic board includes a set of LEDs to help service providers troubleshoot the computer. The LEDs are located on the logic board between the two DIMM riser card connectors. LEDs 3, 4, 5, and 6 are normally off and will automatically illuminate if an error occurs. To read LEDs 1, 2, 7, 8, and 9, you must press the DIAG_LED button, which is adjacent to the LEDs. To press the DIAG_LED button, use the nylon probe tool
LED 2 is of interest
LED 1 Sleep
LED 2 Standby or Trickle Power
Normally on when DIAG_LED button is pressed.
If LED 2 is not on, the symptom would be that the computer won’t power on.
Power-on LED illuminates when pressed in, but goes out when button is released, there is no boot tone or video, but you can hear a small click
Power-on LED illuminates when power button is pressed but fans do not spin (or spin only momentarily) and there is no boot tone or video
Power Supply Verification
To power on, the computer’s logic board requires “trickle” power. If the system fails to power on, first reset the SMC as described in this chapter. If the computer still doesn’t power on, follow the procedure outlined below to determine whether the issue is related to the power supply.
Verify trickle power
Diagnostic LED 2 indicates the presence of trickle power required by the logic board to begin the startup process.
LED 2 should be yellow when the DIAG_ LED button is pressed, indicating that trickle voltage is present.
Verify Power Supply Is Providing Power
Diagnostic LED 8 indicates that the main power is OK and within regulation.
Plug in AC power cord, and press the power-on button on the front panel.
LED 8 should be green when the DIAG_ LED button is pressed, indicating that the main power is OK and within regulation.
If diagnostic LED 5 and LED 6 are both solidly illuminated at power up, improperly seated power supply cables could be one cause of this behavior. Check all power supply cable connections to ensure they are properly seated.
Let us know what you find out.
해당 답변은 도움이 되었습니까?
open the case and clean under the button. dust collects under it and can prevent a connection. also pull the switch wires off the board and re seat them.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 3
30일 전: 11
전체 시간: 226
