Two Broken Connectors On 2DS XL
Unfortunately, the 2DS XL was made to be cheap. As such, it seems that it is incredibly easy to break, both playing with it and during repair. Unfortunately, the latter situation has happened to me.
I disconnected these two cables that go to the bottom screen in order to clean the bottom while replacing a top screen, however I managed to break them during the process due to them being incredibly flimsy. Now, the two cables which they connect can no longer be connected to the board. That being said, I am unaware of any workarounds or any replacement parts for these connectors in particular. Any help is appreciated, thank you.
좋은 질문 입니까?
댓글 3개
Feel you. At least you needed the repair. Mine was a… cosmetic decision. Wanted to replace the c stick “the proper way”
Seth Hannigan 의
But I’m my bad experience, although I broke the actual cable beneath the motherboard, as my little research suggests, you could technically tape it. The actual connector is just there. You can’t simply plug it back like several others. You just put it back in place and press it with the thing that holds it in place. Forgive my lack of proper terminology. But mine was tough to get back when I realized it wouldn’t reattach as in first place. But then I broke the cable, so….
Seth Hannigan 의
I should have mentioned, that taping did not help. Besides, see how mangled the flaps are? I doubt they will make a good connection ever again. I appreciate your advice, but I think I might need new parts instead. The problem, however, is that I am unsure of what kind of connector to get.
Aiden 의
